I wish, bet the staff get killer stock options.In relation to the thread, going off your sig, do you work for NV's power delivery dept?![]()
Time on the QA bench before shipping the whole lot. That it in they lab (possibly using open bench rigs) they found no problems at least at design time.I can't believe that this is even an issue on a card that costs £1600 - what exactly did they skimp on?
Good thing Sapphire aren't an Nvidia AIB as the Nitro line word then be too close to reality.So, even if you make sure it's fully plugged in, and locked, with no gap at all, this is the play that can result from things like reinstalling your side panel or cable management. You basically need to "plug it in all the way" then gently back away as if the connector is some sort of explosive ordinance, lest it back out on you and result in the above gap.
Well, with Nvidia solder defects - aka Bumbgate - users outside of North America got... Nothing.Class action law suit inbound-matter of time, Nv will cave and pay out without accepting liability-if you stay in the US.
Yeah I certainly wouldn't want to buy a used one with 3 months warranty left for example, ticking time bomb.Wonder what will happen to second hand values of these if not much warranty left
I wouldn't touch 4090 full stop until Nvidia have fixed the connectors and that it has been verified to not to melt lol - it's a £1600 card!Yeah I certainly wouldn't want to buy a used one with 3 months warranty left for example, ticking time bomb.
My 90 degree adapter was fully seated and hadn't budged at all and still melted out.
Be careful guys
When was this change made and does it only apply to the 4090?The changes they have made for the revised connector should keep it from melting. They are basically trading catastrophic failure for "Why isn't my graphics card powering up?" failure. The latter failure will be instantly recognized as a problem to the end user, and easly fixed when it occurs.
Igor's lab noticed a 4070 with shorter sense pins back in July, I'm not sure when they started shipping though.When was this change made and does it only apply to the 4090?
I had an LG Nexus 5X smartphone, and there was a problem with the chip that basically meant they were almost guaranteed to fail after a while, usually about 2 years.
In the US they filed and won a class action and people were compensated, of course that legal action didn't apply in the UK and LG didn't want to know.
When did you get your card?Can confirm my 4090 has the new connector on my FE.
The pins are shorter.
The only place in the UK that sells FE cards. I can't link them cos its a competitor.
Cool, but..er.. when?
