Mem-test settings
21 Apr 2008
By the river
I'm after some settings for using memtest.
I'm testing these sticks on an xfx 790i ultra mobo, i've had them at 1.9v and 1800mhz at auto timings - roughly 9/10/10, was looking to tighten these up, but getting a bit lost in the setup.
for example one of the option lists for memory tested gives Bios-std, Bios All or Probe,
Bios STD returns no errors, where as Bios ALL gives errors immeadiately.
On a side note with ddr3 is it best to run the rated fsb at 1:2 e.g at stock cpu 1333mhz fsb mem@1333mhz or is it best to run them 1:1 say cpu @ 1800mhz+ and the ram at half that? or is there negligable difference?
I have noted in the past the crappy WEI peaks when running 1:2! adding to my confusion!
thanks in advance
