- 1 Nov 2005
- York
Any advice would be really good,
I've got the Geil one TCCD kit 1gb, and I now want to go 2gb.
I'll be wanting a 2gb kit that'll perform as well as my geil, mind you I'm not sure I'll see the difference on my kit
I run a 290htt *10 multi and mem at 166mhz and the bus things at 800 each, sorry the ASRock sata2 bios is quite odd.
Whats good or bad, also quite limited on the volts on this mobo.
I'm about to order a the following, from OCUK of course
NEC 20WGX2 20.1"
WD Raptor 36GB *
WD Caviar 250GB
2 x WD cable thingy's *
Plextor px-755SA Sata dvdrw *
* Might not get these and put the cash from them toward a 2gb kit + a bit extra. will spend £180 max
Or am I better off just getting an other fast 1gb kit and adding that ?
NEC 20WGX2 20.1"
WD Raptor 36GB *
WD Caviar 250GB
