Hi All,
Im looking for some advice about RAM.
I have the Z370 Aorus Gaming 5 and an Intel 8700K CPU. I was originally looking at the
8Pack TEAM GROUP DARK PRO " EDITION" 16GB 3200MHZ RAM to go with this.
Now the CPU page only states that the "Supported" RAM it goes up to is DDR4-2666 and anything above that is considered an overclock.
I'm not looking to receive ultimate "cutting edge" performance from my RAM, i'd prefer that it was rock solid stable as a reasonable speed and it doesn't require much tweaking. I only intend to use this machine for gaming with some light Photoshopping as a hobby not a profession.
My questions are
1. Has anybody used this RAM with this setup who could confirm it works?
2. How much more of a performance increase would I see compared to a 2666MHz set of similarly timed RAM? (If at all)
3.Plan is to run 16GB currently and eventually move to 32GB when the prices of RAM drop, If having to use XMP 2.0 to run these at the required speed will this cause issues when installing another 16GB further down the line? (Guess I may have to re-select XMP 2.0 if it resets?)
Any advice would be appreciated.
jwink86
My questions are
jwink86
