Memory advice - swap or mess with timings
8 Sep 2014
Ok I have to admit when it comes to memory my knowledge is limited. I’m aware of cl times and single sided / double but that’s as far it goes.
I could really do with some advice please , currently I have upgrade from 2 - 4 sticks of.
However after running two sticks with no issues @ 4000 now I have installed 4 I have had to drop to 3600 due to memory errors.
I was hoping someone could suggest some timings possibly for these sticks or would I better of exchanging them for something like to tighten or improve speeds.
I did try dram calculator an failed miserably with safe timings.
Or g skillz trident z Neo cl16 2x16 , if I’m going to see perf difference from my current.
Apologies for being dumb here :)
I did the same thing with Patriot Viper Steel - Running Great with 2 sticks @ 4000mhz (although I dropped it to 3800 with lower timings due to not being able to run 2000 FCLK without WHEA errors)
Heres the settings I landed on after going to 4 sticks, mine wont boot above 3666 with any voltage / timings - even XMP -
Thanks bud really appreciate your reply , I’ll try these when I get home and see what difference it makes :)
