Memory Advice Time
16 Jul 2006
Ok with expected arrival of processor gonna need a couple of gig of memory
My system is as follows
AMD Athlon 64 X2 Dual Core 3800+ (Socket 939)
Arctic Cooling Freezer 64 Pro
K8N-Neo4f
Asus Extreme N6600 Silencer 256MB
Casecom KG-868 ATX Full Tower Case
Not to sure what mem to go for was hoping to pay £120 all in
Wanting to do some overclocking on this rig so what would you recommend.
Cheers again
Marc
Any chance on a little more info on what a divider is will also read but youll probably pin it down a bit more in a few sentences than reading a few pages of info
Cheers guys
Marc
Cheers guys
Marc
A divider is a way of running the memory bus slower than the CPU bus.
So if you overclocked your CPU by upping the HTT bus from 200 to 250, without a divider your memory will be running at 250mhz. Using a divider such you can run the memory at a fraction of the HTT speed, so using the 5/6 (aka the 166Mhz) divider you will run your memory at 250 x (5/6) = 207.5Mhz, which PC3200 would be stable at.
On Athlon 32bit platforms running a divider would kill performance, they preferred 1:1 (no divider). But the A64 architecture has very little penalty running with a divider, performance on A64 is simply about CPU speed.
