32-bit XP supports a maximum of 4GB RAM, which includes any memory on the Graphics Card I believe. In the case of ten80p - 3.25GB + 768MB of the 8800GTX in sig = ~4GB
Hardly any games support or even use over or benefit from over 2 gigs of ram xp or vista.
Until they do I'll stick to 2gb.
erm the thread is about xp 32 bit ?Vista 64 Ult with lots of App's is a POS with 2GB, totally waste of time not running 4GB today.
The time to even come out of a game or task switch is massive on 2GB.
Ignore that statement!
Get 4GB it makes a big difference in loading times and application switching and is the cheapest, simplest upgrade for your PC - a price vs performance winner - even though windows only sees ~3.25GB.
No it's not whats the point if nothing uses over 2 gigs buying 4 gig for xp is a waste of money
Im on 2 gigs and app switching is almost instant
Eventually i ended up with Vista Ultimate x64, and it's better again.I had 4Gb with XP 32bit, and it ran fine, but i felt a bit ripped off on the ram i couldn't use. I then upgraded to XP 64bit, and that was a complete waste of time, had so many problems with drivers and softwareEventually i ended up with Vista Ultimate x64, and it's better again.
