- 19 Oct 2010
Hi
I'm trying to diagnose an issue i'm having with my system whilst playing iRacing (it's all I use it for). Randomly the game will "hang" for a few seconds. The game has some onscreen performance counters. One of them indicates i'm having page faults.
"P Letter = Page Fault Meter (PFM), which indicates if you are experiencing page faults because your system is using your disk drive to make up for the lack of available physical RAM (Random Access Memory)."
I'm running a 7800x3d, MSI Tomahawk x670e, 2 x 16gb G.Skill Trident Neo Z5 6000/CL30, Samsung 990 Pro. I've EXPO enabled in the BIOS and i'm running "tight" memory setings. Hopefully I can run something and it shows errors and then I can change things and the errors go away
Thank you.
.Thank you.
