Memory Cache - advice
28 Feb 2004
North East, UK
Hi,
I've currently got 8GB RAM and looking at task manager it says 2156 is cached, so I've only got around 6.5GB free. Do I need to leave as it is or alter the settings?
Thanks.
Seems normal. I have 4.5GB cached currently. Would be interested to know if we are doing something wrong though haha. :p
its normal,cached means stored set aside with the latest used data inside it ready to use again
if you restart your pc it will reset the cache
its nothing to worry about
Yep, I totally knew that.
This did not just make me go "Ohhhhhhhhhh... I should have known that" because I definitely knew that.
*ahem*
