Since im moving to C2D, i have been searching for some budget 2GB kit ram for the E4300. I found these two from Corsair at around the same price, but is the XMS2 worth the extra £4?
Corsair 2GB Value Select PC5300
and
Corsair XMS2-5400C4
Any help would be appreciated.
EDIT: I could get the Gigabyte DS3 motherboard+Corsair Value Select 2GB kit for £168 including P&P. Or the DS3+Corsair XMS2 2GB Kit for £178 including P&P. What is the better option? Also i will be overclocking the E4300 to get to as near 3GHz as possible.
- Nymins
and
Corsair XMS2-5400C4
- Nymins
I know its blasphemous. Thanks for the info. Even though there probably isn't much of a performance difference between the two. The XMS2 has 4-4-4-12 timings, whereas the Value Select has 5-5-5-15. Does that improve performance much since the timings are lower? If anything the XMS2 will look better cause of the heatspreaders
