Memory Compatibility Question
28 Jan 2008
Leeds
Hey, i recently ordered a new setup.
however skimming over the RAM and Motherboard I'm wondering if they will work together when it comes to overclocking the CPU.
the parts are:
OCZ Reaper 6GB (3x2GB) DDR3 16000C9 2000MHz
https://www.overclockers.co.uk/showproduct.php?prodid=MY-202-OC
Asus P6X58D-E Intel X58 (Socket 1366) DDR3
https://www.overclockers.co.uk/showproduct.php?prodid=MB-399-AS
Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366)
https://www.overclockers.co.uk/showproduct.php?prodid=CP-320-IN
Will they be fine together when getting the i7 up to a 4ghz overclock?
thanks in advance :)
cool, he says at the end that his case wasn't very optimal for cooling, only 1 front intake fan. whereas my case is the antec twelve hundred, im guessing this should hopefully keep it nicely cooled.
