24 May 2006 at 18:34 #1 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,894 Hi, I currently have Corsair 1GB DDR2 XMS2-5400 TwinX. My mobo is the Abit AA8 DURAMAX. I want to upgrade to 2GB. Is the motherboard compatible with the new type of Corsair RAM? If not I will have to buy the old type. Thanks!
24 May 2006 at 23:01 #2 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,004 Location Rutland fluff said: Hi, I currently have Corsair 1GB DDR2 XMS2-5400 TwinX. My mobo is the Abit AA8 DURAMAX. I want to upgrade to 2GB. Is the motherboard compatible with the new type of Corsair RAM? If not I will have to buy the old type. Thanks! Click to expand... It should work with any DDR2, compatibility is rarely an issue anymore.
25 May 2006 at 19:36 #3 KIA KIA Man of Honour OP Joined 14 Nov 2004 Posts 13,894 Will my motherboard still be able to take advantage of the speed etc? Would you recommend any other brands instead of Corsair? Thanks. Last edited: 25 May 2006
