Memory compatible?
23 Oct 2002
Ed
Hi,
I have an rather old motherboard: ABIT KX7-333R and it says in the manual that it supports "Four 184-pin DIMM slots support PC1600, PC 2100 DDR SDRAM modules". Was wondering if i buy a PC3200 (as they are relatively cheaper), would it work on my motherboard; somehow managing to work at the slower rate?
Or do i NEED to buy a PC 2700 DDR SDRAM instead?
Help is really appreciated.
Regards,
neoRAGE
as far as i know you can buy the PC3200 memory you want to,
and easily set it to run at the slower speed within the motherboard bios at;
133(DDR266)(PC2100)
or
166(DDR333)(PC2700)
depending on which its happy with
take a look in your bios (and update it to the latest one available) and write down the ram speed options available and post back here... chances are you can
133(DDR266)(PC2100)
or
166(DDR333)(PC2700)
cheers mate.
