Hi guys,
I was using my pc last night no problems then when I try to boot this morning, I get a blank screen and 1 long beep.
I check all connections etc, reseat all the cards etc etc and all are fine.
I have 2xBallistix 4000 512mb sticks of RAM - not overclocked, 1t 2-8-8-10, 2.80volts 200fsb (If I remember correctly)
So I checked it with one stick of RAM in and boot fine. Then I swap the ram to boot with the other stick and same error.
So ive determined it must be the RAM but wanted to know if this was a common problem RAM just dying for no reason? It is about 2 yrs old but Ive never seen it happen before. The RAM had no errors on it when I did a memtest86 check before now.
Im a bit cautious to buy more RAM incase when I use 2 it doesnt work again or breaks again.
Cheers in advance for any advice
