i am running 2x512 sticks of ddr. 1 stick is from and old build which is twinmos branded the new one is OCz.
Now when the computer posts it says dual channel 128bit and when i run cpuz it recognises 2 sticks but if i right click MY COMPUTER and select PROPERTIES it only shows 512.
Also if i ctrl alt del and select performance it also shows physical memory total as 523752.
I am using slot 1 and 2 on a winfast (foxconn) NF4SK8AA board
