Memory displayed on Speccy
27 Mar 2016
Bristolian living in Swindon
Hi all
So I installed Speccy to see whats listed spec wise and see some temps...
Under the RAM section its saying: 16.0GB Dual-Channel Unknown @ 1064MHz (15-15-15-36)
Why is it only showing 1064Mhz and also not showing that its Corsair Vengeance
cheers
ok cheers for the replies will report back once ive installed cpu-z
EDIT: Installed CPU-Z... Clicked on the Memory tab and its also saying DRAM Frequency 1064.1Mhz :confused:
Your ram speed is x2 what is shown in Cpuz, so I assume your running 2133mhz ram.
If your ram should be faster look to see if xmp is set in bios
