Is this kit ott or work well?
https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g400c9k-my-102-pa.html
I don't think so personally, consider the 3600/16 kit runs at 1.35 the ripped 3600/14 kit 1.45, now if you boost the voltage to 1.45 on the 3600/16 kit it will most likely do 3600/14.Is the ripped worth the extra?
i bought the 3200/14, ran it at 1.45v 3600/14 - saved me £20, sortedYou recommend the 3200/14 or 3600/16 then?
