27 Jul 2006 at 08:19 #1 Nismo Nismo Soldato Joined 17 Oct 2002 Posts 18,543 Location UK Been out of the loop on PC hardware for quite a while, so want to check what memory should be used with this... Intel Celeron D 331 2.67GHz (LGA775) Am I right in thinking I can just use 'normal' DDR PC3200 memory with it? Thanks
27 Jul 2006 at 08:42 #2 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,006 Location Rutland Nismo said: Been out of the loop on PC hardware for quite a while, so want to check what memory should be used with this... Intel Celeron D 331 2.67GHz (LGA775) Am I right in thinking I can just use 'normal' DDR PC3200 memory with it? Thanks Click to expand... Most LGA775 boards use DDR2 don't they?
27 Jul 2006 at 08:54 #3 Nismo Nismo Soldato OP Joined 17 Oct 2002 Posts 18,543 Location UK Minstadave said: Most LGA775 boards use DDR2 don't they? Click to expand... Seems some of them do, and some of them don't. The mATX boards based on the i865G chipset I'm looking at seem to take DDR1. Can a Celeron D run with that type of RAM?
27 Jul 2006 at 10:57 #4 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 33,006 Location Rutland Nismo said: Seems some of them do, and some of them don't. The mATX boards based on the i865G chipset I'm looking at seem to take DDR1. Can a Celeron D run with that type of RAM? Click to expand... Yup, if the board has DDR support, PC3200 will be fine
