hello all
probably discussed here before but i have to ask anyway as this memory is not cheap?
but which memory as i,m not sure about intel and the best latencies for performace?
I,m not a overclocker by the way
i,m thinking of getting a conroe e6700 with:
Asus p965 or 975x motherboard
x1900xt
memory:
OCZ 2GB (2 x 1GB) PC2-8000 Dual Channel XTC Platinum Series EL-DDR2 (OCZ2P10002G-K) (MY-066-OC)
- 1000MHz DDR2
- CL 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Platinum Mirrored XTC Heatspreader
- Lifetime Warranty
- 2.6 Volts
- 240 Pin DIMM
- Enhanced Latency Technology
- 2.1V EVP
£352
or
OCZ 2GB (2 x 1GB) PC2-8000 Dual Channel Extreme Edition XTC Platinum Series EL-DDR2 (OCZ2P10002GEEK) (MY-068-OC)
- 1000MHz DDR2
- CL 4-5-4-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Lifetime Warranty
- 2.6 Volts
- 240 Pin DIMM
- 2.2V EVP
£317
do you have to overclock these for them to run 1000MHz DDR2 ?
would these be ok for an asus board of either chipsest?
thanks
x1900xt
memory:
- 1000MHz DDR2
- Unbuffered
- Lifetime Warranty
- 2.6 Volts
- 240 Pin DIMM
- 2.1V EVP
£352
or
- 1000MHz DDR2
- Unbuffered
- Lifetime Warranty
- 2.6 Volts
- 240 Pin DIMM
- 2.2V EVP
£317
thanks
