- 9 Nov 2019
whats ideal ram kit for x870e expo? im seeing 6000 cl 30
but what aboout expo? i see when ordering a kit it says xmp or expo, i cant see 8000 expoPress and forget = 6000
Probably okay, but some luck needed = 6400
Faster on occassion, but fiddly = 8000
DDR5 Memory Performance Scaling with AMD Zen 5
Our AMD Zen 5 Memory Scaling Review examines six different DDR5 memory speeds, including DDR5-8000, DDR5-6400 1:1, DDR5-6400 CL28 and others. We looked into how these speeds impact performance in gaming at four resolutions and a wide range of application workloads.www.techpowerup.com
Kits above 6000 are far more commonly XMP, since AM5 / 7000 CPUs worked best with that speed on release.but what aboout expo? i see when ordering a kit it says xmp or expo, i cant see 8000 expo
You can do it on the old ones (board dependent and you'd probably need a BIOS update), it was just not worth bothering with except for the lols.on AM5 i assume the new chips??
and bragging right's lolit was just not worth bothering with except for the lols.
