Memory for new build
11 Aug 2005
Looking for advice of what DDR4 memory to buy for a new build around the following:
Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail
Asrock Z170 Extreme6 Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Samsung 850 EVO Series mSATA 250GB SATA 6Gbps Solid State Drive
Haven't a clue what to get other than it needs to be dual channel and that I am after 16Gb.
Should I buy 3200 as this is the Max mobo takes?
What timings should I be looking for?
I want something that I can overclock but I don't plan to do any over clicking until a few years down the line.
Hoping build will last for 4-5 years. Not planning on any serious gaming so just using gpu over dedicated graphics.
I doubt RAM is going to matter much, nor speeds or timings - Anything CL15/16 @ 2400-3000 will be fine.
If you plan to use your RAM at over 2400 it's going to require some tinkering with XMP profiles and such, so 2400 should be fine.
I advise 2x8gb kit, so if you do need it down the line, you can pop 2x8gb more in and you'll have 32gb.
YOUR BASKET
1 x Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FBK2/16) £89.99
Total : £89.99 (includes shipping : Ex.VAT).
