Memory for X79
If you will mainly be multiplier clocking, then you may as well stick with 1600/1666 RAM.
The Kingston HyperX PC3-12800 quad channel kits are good, and cheap.
I've got 32GB of the stuff in mine :)
Did look at those but i'm going for a more black build this time, not after anything with a green pcb.
Would just buy 2 dual chan kits. The quad dominator kit is an interesting option though.
Dual channel kits are not tuned for X79 you may well run into troubles. Your better with a correctly tuned quad channel X79 kit. X79 is quad not dual channel after all.
Correctly "Tuned" X79 memory? lol
Just get 2 x Dual Channel Samsung Green kits and enjoy their speed.
Scoff but memory is where most problems arise on this format. Two dual channel kits are not the same as one quad channel kit take a second and visit forums such as ROG and you will see what I am saying. Any slight difference in the carecteristics in two dual channel kits will cause instability.
Have run 3 dual channel kits in tripple channel for yonks with no problems as well.
Still not 100% but i think the samsungs are ahead.
Ahahahaha. no.
