I want to upgrade my old system with some faster memory , i am using 2 GB PC3200 DDR 400 , can i use any better of faster , my motherboard is Asus A8N-SLI Deluxe socket 939
Is that 2 x 1gb sticks? If so, then drop the Command Rate to 1T. AMD systems take a fair hit running on 2T.
You could fork out near £200 for some that runs at 2-3-2-5, but that would be a waste of money IMO. Unless you could nearly cover it by selling your current sticks.
Well that single change should make your current RAM run a bit faster. Tho, just like buying a new 2-3-2-5 set, you probably won't notice the difference.
