Memory Help
7 Jan 2006
I am looking for some better memory of faster . at the moment i have 2GB PC3200 , can anyone help or point me in the right direction :)
My System
FX 57
Asus A8N-SLi Deluxe nForce4 SLi
What exact sticks do you have now?
As you have an FX, you probably don't need high FSB RAM as you can just use the multiplier. So go for tight timing RAM e.g. G.Skill 2GB ZX or Corsair 2GB XMS3500LL Pro.
Budget? Then the G.skill, if not, go for the Corsair as it will clock higher I should think.
