memory info ?
27 Jan 2005
Letchworth Herts uk
Hi All i want a bit of advice , i have a p.c with Vista 32x and currently run 2gig memory , can i upgrade to 4 gig , will my system run on this ?
my details are :
E6600 cpu
Asus 5KP Deluxe m/b
9800 GFX
2 gig 6400 memory
no, becuase your on a 32bit opertaion system it will only recognise 3GB of the RAM t will run but at reduced size.
if you want to take advantage of 4GB or more then you will have to upgrade to a 64bit operating system
okay thanks , so it will work if i put 4 gig in it ? but reduce it to 3gig ? :confused:
