http://www.overclockers.co.uk/showproduct.php?prodid=CP-280-IN
http://www.overclockers.co.uk/showproduct.php?prodid=MB-320-AS
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-NC
http://www.overclockers.co.uk/showproduct.php?prodid=MY-136-OC
at the bios/boot screen it displays DDR3 6gb 1066mhz (or 1086 ?! I am at work and can't check now)
any idea? should it display 1866mhz? any settings in bios?
how easy is to overclock the i7? say to 3.3-3.5... something easy to reach and with directions what to change in bios please? Noctua cpu fans (both + 2 case fans...Antec P180 case) are both using the ULNA adapters....
thank you
thank you
