Memory issue
17 Feb 2012
I'm having a problem simply changing the speed (Mhz) of my RAM in the BIOS; the system won't boot at 1866Mhz. (Resets after applying changes, then boots - except leaves the screen blank. As if there's no video input).
I've updated the BIOS, checked the seating on the Memory, chcked for errors using MEMTEST86+, any suggestions?
The CPU: http://www.overclockers.co.uk/showproduct.php?prodid=CP-339-AM&groupid=701&catid=1967&subcat=1825
The Motherboard: https://www.overclockers.co.uk/showproduct.php?prodid=MB-194-MS
The Memory: https://www.overclockers.co.uk/showproduct.php?prodid=MY-147-GL
Have you set the RAM voltage and timings correctly in the BIOS? If so, try giving the RAM more volts - 1.6v should be very safe, possibly more. It may also be that you need to amend multipliers - I'm not up with current AMD cpus but I expect someone else will be able to advise on that.
