Memory issue?
2 Dec 2004
Under The Desk, Wales
I have an old tablet. It has 2gb memory. Samsung tab A 10" (2016)
Every 20mins or so, the internet pages slow to a stop and i have to go into the settings and clear the memory as it drops down to around 400mb available. Once i clear that and the memory available goes up to around 900mb the internet is fine for a short while.
Is it because i dont have enough memory?
The only thing that is showing as a memory guzzler is Samsung internet. All other apps are using small amounts of memory. Plus, i dont have many apps on the tablet.
Is it time for a new tablet with more memory?
Perform a factory reset of the device and retest. If it's the same it sounds borked because 2gb of memory should be fine for what you're doing.
2gb not enough i think. After memory used for the system only left with approx 800mb.
Soon as i go on internet it drops to around 400 - 500mb available. Thats when it slows down then. I got to keep clearing up ram.
Think a new tablet with a lot more ram needed.
6gb model would be good but, dont want to spend much....
Any ideas? Ta
This any good:
TECLAST M40
