memory management bsod and now crashing
18 Feb 2013
Hi there,
I was hoping that maby someone out there could help me.
I have built a new rig and overclocked it. Everything is going fine, passed prime and also intel burn test on the highest setting.
I do not have an additional graphics card, i am just running the intel hd 4000.
At first when gaming i kept on getting the BSOD, first it was error 1a and then i had an error 24. I have looked into it, and it seems it is a RAM problem.
I ran a memory test and it passed it not problem, i had a look around and thought it might be to do with the DRAM voltage and the VTT. I have adjusted these, and after a week or so i have had no more BSOD.
I do not know what is going on now, it seems that after an hr of gaming, the game crashes and i get a display error.
I have changed the processing time and also the time out detection. It now just freezes and wont go back to the desktop.
Does anyone have any idea what the problem may be??
its starting to drive me crazy!!!
i am going to pick up a 7950 in a couple of weeks, do you think that this might help?
also does anyone know how to set the timeout and processing time back to default?
Many thanks, any help would be amazing
if your using onboard graphics while overclocked it will probably crash,last time I used onboard it wasn't very stable
I would set it to stock clocks until your graphic card arrives,then see how it performs with it installed
I'm having lots of BSOD's on my new 3570k and I'm certain it is the memory controller that is faulty. I can run memtest and prime95, intel burn test without any problems but as soon as I start to use the computer for everyday use I get lots of 'application has stopped working' errors and various BSODS. This happens with the internal graphics and a HD 4850. Did you buy the processor from OcUK?
