Memory management error
All settings as per your last post but during stres core v is sitting at 1.32v.
Also not sure what the accuracy is but in task manager CPU speed is reading 5.17Ghz
cpu-z will tell you correct speed
can try medium llc now and -0.005v dvid then see where load cpu voltages are
Cool just managed a game there for about 20 mins without issue. I will try knocking it down a bit and see.
Once again many thanks!
Also is there a reason that this has only just started playing up when it has been fine for so long?
Ok so I dropped the LLC down to medium and dvid back to 0.005v and it was sat at 1.308v
I have just noticed though you said negative 0.005v!
1.296v now so it's getting better, is it a case of just dropping it down bit by bit till I reach 1.255v
Edit*****
-0.015v is giving me 1.284v, should I keep dropping it or just roll with that?
Edit 2****
-0.025v and it stays at 1.284v under load
you could try low loadline calibration and -0.020v see what that says
it depends on your cpu in how much voltage it needs to be stable in games,if games were crashing to desktop with 1.255v id aim for around 1.260-1.270v mark
Well I will leave it as it is as everything seems to be fine at the moment, I will try llc to low and see how it goes.
Many Thanks for the info!
