Memory management error
20 Nov 2005
Redditch
I'm occasionally getting a memory management error with Windows 10, usually after exiting a game. Not game specific.
Would you say it's a ram problem or cpu memory controller issue?
Cpu (7700k) is overclocked to 5ghz, 1.34v, memory is running default 3000mhz & stock timings 1.35v
Doesn't seem to be a pattern as to when it can happen, but it does seem to be when exiting a gaming session.
I've run memory test in Windows & memtest for 3 or 4 hours with no errors.
Any other tests I could run to pinpoint the problem?
