Well my RAM is Backordered due to stock shortage, but what I forgot to do is check on the Motherboards compatible ram, which upon looking the Corsair vengeance ram I have chosen is not there. Is this just due to the mass amount of different models/manufacturers that only a few are tested on my system or will they outright not work.
Ive also looked at some other ram which I was considering buying which isnt on their either, the patriot viper which is a different model to the one stock on ocuk.
Surely it should still work shouldnt it?
