Greetings all,
bit of a strange question.
but i have 4 gig of patriot memory
namely this; http://www.patriotmem.com/products/detailp.jsp?prodline=5&catid=61&prodgroupid=165&id=910&type=1
and i have this motherboard
namely this; http://www.gigabyte.com/products/product-page.aspx?pid=3258#ov
and it's just occured to me that the memory is 2000mhz rated.
However the Mother board does support up to 1600mhz OC.
now where my confusion comes from it that on any occassion i've tried 1600mhz i've had many freeze to restarts as i'm pretty sure it's not setup right in regards to voltage, the motherboard has chosen 1.50v automatically.
The RAM on the technical sheet (see website) says it's 1.65v @ 2000mhz, and there 1600mhz RAM suggests the same voltage.
Not knowing a lot about motherboards (never found the manuals very useful) Im not sure if increasing the voltage to 1.65v is wise, as i'm not sure what the motherboard will do, in regards to other components. I've stories about the RAM voltage also effecting other components. is this true, the section in the manual about the RAM suggests the following;
DRAM Voltage Control
Allows you to set memory voltage.
Normal Supplies the memory voltage as required. (Default)
1.275V ~ 2.445V The adjustable range is from 1.275V to 2.445V.
Note: Increasing memory voltage may result in damage to the memory or reduce the useful life of the memory.
i can manually set the mhz to 1600mhz, but am unsure of what changing the voltage will do?
if someone could shed some light on this i'd be really appreciative, the RAM turns out to be tested on a Intel system by Patriot but not a AMD system, so there are no settings from them.
Thanks,
Luke.
Thanks,
Luke.
