- 17 May 2020
Ok so I'd like to pick someone's brains, I'll start with system spec.
10700k, asus prime a, corsair 32gb 3200mhz 16-18-18-36, 2070 s, 750w psu
Now my cpu is oc'd to 5ghz all core and cache is 4.7. Now here's where the fun starts, I have 4x 8gb memory sticks with xmp enabled, now when I try to push past these settings with speed or timings it fails with a dram voltage of up to 1.5v and system 1.3 (haven't pushed past these) so I look into it further and find out that occupying 4 dimm slots could be my problem, so ok I take 2 out and try 16gb now my computer won't boot, I remove oc and xmp and it boots, thinking maybe it just needed to be booted to calibrate to 16gb I restart load bios and enable xmp, still no oc on cores and low and behold it won't boot with just xmp, add all memory and it boots fine lol
Now I'm new to memory overclocking so could be missing something obvious but for the life of me I can't figure out why 16gb won't boot with just xmp.
I'll also add taiphoon burner tells me I have Samsung b-die
