Memory problem I think - help please?
31 Oct 2004
Hello Everyone,
I wonder if anyone could offer me, a techno challenged induvidual, assistance with problems with an upgrade to my computer.
I've had and Intel Core Duo E6600, Geforce 8800 GTS, 2gig Geil PC 6400 800mhZ DDR2 memory in my XP installed computer for ages, and have had no trouble with it at all.
With prices dropping, I thought I'd upgrade, and bought an Intel Core Duo 3.16, ATI 4870 Graphics card, and another 2gig of Geil PC 6400 800mhZ DDR2 memory. I also got Vista 64.
I got Vista installed, but had no end of crashes with it. I then tried to install XP again, and it failsevery time copying files to the hard disk during pre install (blue text type screen). I've scoured the interweb, and according to what I read the symptoms point to faulty/mismatched ram. The dual channel kits I have are identical, and I wonder if there is a problem running it with the faster CPU?
As said, I'm not a hardware expert, and I'm just about pulling my hair out, well whats left of it, and any help will earn eternal gratitude.
Sorry, as said I dont know a great deal about this, just learning - the hard way the way things are going. No, haven't altered any volatages, I've just left eveything in the bios on auto to be honest - I thought it would auto-figure for the new hardware? I would have to add, the XP install failing happens with only 2gig installed.
I have and Asus P5B motherboard, which I just flashed to the latest bios from the Asus site - seemed to work ok as it sees the faster chip and it couldnt before. I'll have a look at the voltage/timings. Thank you for taking the trouble to reply - appreciated.
I just looked at the memory voltage. On the Ram it says it should be 2.1V, and when I set that in the bios the value turn red - indicating it's too high? It turn red at 1.90V? I'm a bit puzzled by this. Cant see where to alter the timings?
That makes sense, thanks you. I have run one dual channel kit at the default voltage 1.80V, for ages with no problems? Is it adding the second dual channel kit that puts a strain on the voltage, resulting, in my situation, in the need to set the rated voltage,2.10V, for the memory?
