Hi All I,m overclocking my E6600 CPU and i,ve got the fsb set at 400 and the multi is at 9 the RAM timing is : 5-5-5-18 everything else is on auto .But i get this on CPUZ memory
Dram Feq 400mhz
Fsb
ram 1 :1
Cas : 3.3.0 clocks
Ras to Cas 6 clocks
Ras to Preharge 6 clocks
cycle time 18 clocks
command Rate 2T
Dram Feq 400mhz
Fsb
ram 1 :1 Cas : 3.3.0 clocks
Ras to Cas 6 clocks
command Rate 2T
