Hello,
I've purchased a 4 x 4GB Team Extreme 2133MHz Kit from Overclockers about 4 months ago.
When I put all of the DIMMS in my PC, It wouldnt Boot, I got a Memory Warning Light on my Motherboard and that was it.
After A lot of testing and swapping about it turns out that one of the DIMMS doesnt seem to work with the others?
If its in by it self it works perfectly, but if the rest of the DIMMS are plugged in then the PC wont boot.
So I've kind of left it for quite a while and been running 3 DIMMS, although come to a point where I really want to get it sorted...
Any tips on what to look out for to try and fix the issue? Maybe its unstable?
Any Help would be very appreciated!
Thanks.
Thanks.
