i had some trouble recently getting my pc to start up. i tested parts in another pc and all seemed to be fine, put mine back together and nothing worked. just on the off chance, i took one of the stcks of ram out and tried it on one stick, it worked. i then tried swappint the twosticks and running it on the one i took out origionaly, it worked again, now its running on both sticks and seems fine.
is there any diagnostic i can run to try and find out where the problem is? havent got a floppy drive to try memtest though. im assuming its the ram that was causing the problem.
