memory problems...
13 Dec 2010
Hi there. Wondering if you guys could help me out a bit.
Here's the problems:
  • prime95 fails on blend but other tests are fine
  • memtest fails with both ddr3 sticks in but not with one stick of either
  • system fails to boot several times
Here's what ive tried to fix it:
  • Set memory timings and voltage to xms3 corsair standard settings
  • updated the bios to the latest version
  • bought a new ocz modstream 500w psu to replace the old POS
  • changed command rate from 1t to 2t, no difference
Any ideas on things to try? the motherboard was a a-grade one from ocuk, so im starting to wonder whether there is a problem unrelated to memory.
