Hi all,
a friend of mine has this montherboard
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1958
he's has this memory installed:
http://www.ocztechnology.com/produc...00_2x1024mb_platinum_edition_dual_channel_kit
I'm guessing that the ram has been running at 333mhz insted of 400mhz he wants to get the best memory he can for his system as he uses it for viedo editing etc.
He's asked me if he buy's another 1 gig stick of the ram he currently has would he get the full 400mhz out of the ram?
if this doesn't work can someone spec the max quallity + fastest he can use.
Thanks in advance
Mp4
Thanks in advance
Mp4
