Hi all,
I just want to confirm that this will work together, I think it does, but confirmation from people that know their stuff is always nice before attempting things!
I got one each of these OCZ memory sets..
OCZ DDR2 PC2-6400 Platinum Revision 2 Dual Channel 2GB (2x1GB)
800MHz DDR2, CL 4-4-4-15, Unbuffered, Platinum Mirrored XTC Heatspreader, 1.9 - 2.1 Volts
OCZ DDR2 PC2-6400 Titanium EPP-Ready Dual Channel 4GB (2x2GB)
800MHz DDR2, CL 4-4-4-15, Unbuffered, Titanium XTC Heatspreader, 2.2 Volts,
Now, everything is the same apart from the voltage so not sure if they would work together without problem? So my question really is, would that create a problem for me if I want to use them all together to get 6GB of memory in my machine? (I have Win7 64Bit as my main machine, will sometimes use my XP Pro 32Bit and I know it wont use it all but it wont be a problem running a 32bit with 6GB memory would it? Seems like the questions are just pilling up here!
Also, I got another set of 2x1GB OCZ sticks, same as above but they are broke, can't even get my PC to load the boat screen when using them. OCZ has a lifetime warranty, would it be worth to RMA them back to OCZ? (Bought them from here just over a year ago so has to be OCZ right?) Reason I am asking I only paid £20 for them and I saw in another thread it will cost about £8 just to get a new pair.. which I can't really use.. although I guess I could sell them in pair with my other 2x1GB set when they are back.. hmmm..
Well, anyway, main question is can I use the 2x1Gb and 2x2GB together without having to play around with the voltage?
Also, would like to hear if you would RMA the memory back to OCZ if it was your sticks?
)Also, I got another set of 2x1GB OCZ sticks, same as above but they are broke, can't even get my PC to load the boat screen when using them. OCZ has a lifetime warranty, would it be worth to RMA them back to OCZ? (Bought them from here just over a year ago so has to be OCZ right?) Reason I am asking I only paid £20 for them and I saw in another thread it will cost about £8 just to get a new pair.. which I can't really use.. although I guess I could sell them in pair with my other 2x1GB set when they are back.. hmmm..
