Memory Question
14 Jun 2012
Im currently getting a new PC for work and the new junior graduate is getting my old machine.
Now the machine in question is a Dell Precision T5400.
Intel Xeon E4510
4GB DDR 2 PC 5300 RAM
Nvidia Quadro NVS 290
Bascially my team leader wants to know what parts are needed to give it a bit of a performance boost (Bascially this machine isnt fit for purpose but giving it a parts upgrade is cheaper than a new machine, im the lucky one who gets the new machine.)
From my what I know I think its the RAM and GFX that are letting it down.
Do you think more than and a better GFX card will do the trick and if so which ones should I buy? Reading up on the motherboard it only seems to take ECC memory which seems really expensive.
Any ideas?
Cheers,
Rich
What is this going to be used for exactly? The GPU probably isn't worth upgrading unless you're gaming or intend to use OpenCL/CUDA accelerated tasks. 4GB of RAM won't be the issue with the system either (even though it is "slow" RAM). I guess to speed it up in normal usage you could buy a fast HDD or even an SSD for it (cost around £70-80 for a 120GB one).
Its a workstation used for 3D modelling and rendering, so im guessing more RAM will be important?
Im thinking a newer Nvidia card and some more RAM and a SSD hard drive will give it a performance boost?
