OCZ 2GB DDR3 PC3-10666C7 1333MHz Platinum (4x1GB) Dual Channel DDR3 (OCZ3P13332GK)
My computer has started to lock/Freeze.
I believe it is a memory problem as it only occurs with two of the four sticks.
The problem is if I run MemTest86 on these two sticks they get no errors.
My window Vista is up to date with the patch that reported some problems using more than 2GB.
Is there anything else I can do?
I cannot ask for an RMA if the Memtest show no errors, but I cannot continue using them either.
