Hi All
Recently built a system consisting of
Gigabyte B550m DS3H motherboard, says on the box Ryzen 5xxx ready. I know some older versions of this motherboard needed a BIOS update to work.
AMD Ryzen 5 5600G
Corsair vengeance LPX DDR4 32GB 3600 CL18 Ryzen tuned kit.
Every thing seemed to be running ok with Windows 11 but I have noticed that the reported RAM speed is only 2666 both in BIOS and using the Gigabyte Easytune software. First thought was did I receive the correct memory as I didnt check when installing but checked the packet, which was sealed when received, and it is as ordered.
Everything is supposed to be compatible so I would have thought it would have automatically picked up RAM speed as 3600.
Tried adjusting up a little in the Easytune s/w but just a slight increase caused the system to be un-bootable. Cleared CMOS and fortunately it sprang back into life. My question is it appears I can up it in BIOS but which setting do I change, Multiplier or clock frequency?
Any help appreciated.
John
AMD Ryzen 5 5600G
John
