Hi
Currently have installed 4x1GB PC5300 Geil 5-5-5-15. CPU-Z shows the correct timmings except the memory is running at 2T, is it possible to run at
1T?
There are no options in the bios to maually set this, is it a case of upping the voltage to 2.1 (currently 1.85). Or as i tend to run processor at stock, lowering the mem speed to 266 and upping the volts?
Thanks
1T?
Thanks
