Memory Size Reporting Incorrectly?
29 Nov 2007
Hi Folks
I've just built a nice new i7 rig and I've got a wierd problem. When I boot up the start up screen only shows 4gb of memory when I have 6gb installed, its also the same if I run memtest86+ and in windows7 task manager. If I run any diagnostic tools from windows I can see all three sticks.
My system specs are:
i7 920 D0
Gigabyte GA-EX58
6gb Corsair XMS3 1600C7 (TR3X6G1600C7)
The memory completes memtest with no errors.
Any help would be much appreciated
Dan
Try running the RAM in pairs, using different slots. If there's a problem with a module or port, then some tests should come up showing 2GB, so you can narrow it down..
