- 30 Sep 2009
- Beccles, Suffolk
i7-4790k
Z97X-SOC Force
TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz
I don't want to overclock the CPU or RAM. I know Memory on auto = 1333MHz which is normal. Do I set the memory to XMP(which I don't like) or do it manually. Am I safe going into the bios and manually changing the speed to 2133Mhz, timings to 11-11-11-31 and voltage 1.65v and that's it or will it affect other settings and require other changes. Just a little confused. thankyou for any help.
I should add that changing RAM to XMP on my previous board affected the idling voltage on my CPU which is the reason I don't like it. It might have changed or be different between boards but I still prefer manual
Z97X-SOC Force
