I just bought 32gb 3200mhz Team Group Vulcan Z T-Force and 1 of the memory sticks is running at below 3000mhz and the other is running at 3200mhz. Why is this? Is there something I need to enable to get the full speed or is it dodgy ram?
OK It looks like the memory that Overclock sent me/sold me was for single channel not dual channel. To confirmed I have the code to prove it is single not dual. TLZGD432G3200HC16CDC01 and confirmed on the msi website.
So yes i put it in the correct channels
and i bought 3200mhz 32gb ram
i looked up the code that is at the back on the msi website which is my motherboard and it turns out that they are for single not dual!
My motherboard is B450M PRO-VDH MAX. On the compapatable list the memory that i bought is listed as single not dual memory. i was using speccy and i looked in my bios for the speed.
That's not single/dual channel it's actually single/dual sided meaning that the chips are all on one side or on both sides. It usually makes little or no difference to compatibility. The memory compatibility lists are never updated as it would be impossible for them to test every combination.
Your sticks need to be in slots DimmA2 and DimmB2 which is slots 2 and 4 counting outwards from the CPU. You then need to go into the bios and select the correct XMP profile. It may also be worth updating the bios the latest of which is 7A38vB7 dated 16th June 2020. It is especially important to keep up with bios updates on Ryzen boards as there have been many performance increases and compatibility fixes. If you do update the bios DO NOT use Live Update. Download the bios to a USB stick and use the tool in the actual bios to flash.
