Hi,
I bought the Asus PK5C motherboard from here in around November/early December. My CPU is the Intel Core 2 Duo E6750 (1033 fsb). For some reason since yesterday the system has been really unstable. I also purchased the following RAM:
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2 (OCZ2N1066SR2GK)
Since building the pc on automatic the mobo set the ram speed to 667mhz. It began crashing as of yesterday and i narrowed this down to a voltage problem, therefore i set the voltage to 2.2v as the range is 2.1 - 2.2v with the protection on the ram set to 2.35v. The system has now become stable again, running at 887mhz ram.
However the problem i'm having is I cannot get the computer to boot with the ram set manually to 1066mhz, it simply won't do it. Am i doing something wrong? 887mhz is currently the best i can get from the RAM, which is obviously below stock speed.
Thanks in advance,
Dan
Thanks in advance,
Dan
