Memory speed issue
You will need to enter the BIOS and either use the XMP/DOCP profile to set the speed or set it manually. The default is 2133mhz.
If you haven't already I would also make sure that you are on the latest BIOS for that motherboard as well. They usually try and iron out memory issues with later BIOS releases.
